SetFlipMirror
Set flip and mirror value in the sensor.
SetFlipMirror(
SENSOR_HANDLE *pstHandle,
STF_U8 u8Flag
| u8Flag | Flip and mirror status | Input |
| Return | Description |
| 0 | Success |
| Other values | Failure |
None
